#2 |
Banned
Member Sales Rating: (1)
There is really no such thing as an RCA patch cable. A balanced input needs a "shorting device" to trick a balanced input into acting like an RCA input. This is what the cable you are referring to does.
Balanced inputs lower the noise level 6db. Thats a bunch. Having a balanced amp is a VERY good thing. To do it justice, you need a balanced preamp and preferable a balanced source (cd player). What balanced inputs do is cancel any noise that is picked up in the transmission cables. A balanced 2-channel amp has twice the circuitry that a normal amp has. You should do it justice by respecting the XLR inputs and use them if at all possible. Balanced amps are a treasure. But, you need a balanced pre-amp to enjoy them - at minimum. Pro-audio is XLR. Here is the heirarchy: Lowest: Receiver. Mid-low: Receiver + external amp. Mid-High: Preamp + Amp. Hi: Balanced Preamp + Balanced Amp Very High: Balanced CD + Balanced Preamp + Balanced Amp Enjoy your amp. What brand is it? |
#3 |
Old School
I did not know that...
Thanks rskarvan...
__________________
More later, Tour... SOPA-PIAS Taste Good "There is a certain entertainment value in ripping the occaisonal (sic) buttmunch..." - TroyD "Death doesn't come with a Uhaul" - Dennis Gardner "Life's been good to me so far" - J. Walsh Stripped down system flooded by Ike (thanks alot motherf----r) ... SDA CRS+ (floaters) - Carver C4 Pre (anchor) - Carver M4.0 (survivor by ~1") |
#4 |
Polkazoid
Member Sales Rating: (0)
Thanks for the info, I haven't bought my amp yet, but I am looking at used Carver Pro series amps. Not sure I have the dough for a balanced preamp so I will probably be using the amp with unbalanced inputs for the time being.
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
