Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 02-05-2003, 05:50 PM   #1
d_gil
Polkie
Member Sales Rating: (0)
Default Polk Subwoofer wiring problem
hi, im the owner of a polk psw 250 subwoofer, the thing is that the amplifier of this woofer has 2 rca imputs (left chanel and right), and mi yamaha home theater receiver (yamaha rx-v995) only has one subwooer rca output, wich is the best way of connecting this two things
thanks
d_gil is offline   Reply With Quote
Old 02-05-2003, 06:16 PM   #2
Dr. Spec
Polk Expert
Member Sales Rating: (1)
Default
Set all the speakers to small on your receiver.
Set the sub to yes/on.
Set the sub volume at the receiver to a little less than the mid point of the range.
Run the rca cable to either input on the sub.
Turn the sub filter to its highest setting.
Adjust bass volume at the sub plate amp to blend well with your other speakers.
If you want to eventually get into system calibration with test tones and an SPL meter, get back to us. For now, this is a good starting point.
Doc
__________________
Ed Mullen
Customer Service Director / Product Development Manager
SV Sound International
www.svsound.com
sales@svsound.com
techsupport@svsound.com
LSi-7
F/X 1000
CS245i
Dr. Spec is offline   Reply With Quote
Old 02-05-2003, 06:51 PM   #3
d_gil
Polkie
Default
Thanks a lot, but the problem is with the rca cable because the receiver only has 1 sub output and the sub has 2 rca imput, y have to connect the rca output from the receiver to both left and right in the sub or only to one of the (left or right)??
thanks
Old 02-05-2003, 07:02 PM   #4
phuz
Polkologist
Member Sales Rating: (4)
Send a message via AIM to phuz Send a message via Yahoo to phuz
Default
Only one.
If you really want to, you can get a Y splitter and use both the left and right inputs on the sub.. but you don't have to and the only thing that will do is give you an additional 3db is sound - an additional 3db of sound that you don't really need.
phuz is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
