| Register | System Showcase | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#1 |
Polkie
Member Sales Rating: (0)
Ok, I'm getting a little frustrated and need some advice. I have a Denon 1803 with a full set a Klipsch speakers, but the subwoofer is the Polk PSW 202. All speakers are working except the subwoofer. I am using an optical cable (Acustic Research) to go from my DVD player to the receiver. I'm using a Monster THX cable from the subout port on the receiver to the Line In port of the subwoofer. I have set the subwoofer to "on" in the receiver setup. The crossover is set to 80 Hz. The subwoofer mode is set to +Main in the receiver setup. I have tried many different combinations , but to no avail. Any advice to get the sub working would be greatly appreciated.
#3 |
Polkateer
You are a big help sid...you need to think before you post...and in the words of Russman, "post less, much less."
River, I am not familar with this sub. First thing I would do is make sure it is turned on, we have all made that mistake at one time or another. You might try a y-splitter into both the left and right inputs to the sub. Double check the owners manual to your Denon and make sure you have the receiver set properly. If all else fails try hooking it up via speaker level connections just to make sure the sub actually works. If it does't you may have a defective sub. Welcome to the fray...you can learn a lot here!!! Hope this helps! Regards, Nat
__________________
RTi10 CSi5 RTi28 SVS PB12-ISD2 Denon 2106(pre/pro) Adcom 5503(200x3) Audioquest Diamondback ICS Kimber Kable 8tc biwire(mains and center) "Don't let your silly dreams fall in between the crack of the bed and the wall." -J. James |
#4 |
Polkazoid
My advice would be one of two things:
Hope this helps.
__________________
Damn....8 lines...I've gotta put my sig on a diet now.... |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
