| Register | System Showcase | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#1 |
Polkie
Member Sales Rating: (0)
I currently have digital cable and recently purchased S-Video cables, digital coax audio and standard RCA audio to run from the digital cable box to the receiver. All is well with watching/listening to the TV. The issue I'm having is with being able to record through the VCR. I've tried every possible routing of the wires and I just can't seem to get audio to the VCR. I'm able to get video, but no audio. I'm also able to play videos in the VCR with no problems. Below is the current setup I have from the digtal cable box to the receiver.
Digital Cable to Receiver S-Video out ->S-Video In (Video 2) Coax Digital Audio out ->Coax Digital Audio In (Video 2) RCA Audio out -> RCA Audio in (Video 2) I think the issue I'm having is with the S-Video out going to the Video 2 on the receiver and I'm not able to put the VCR somewhere in the middle. I'm able to run RCA Video from the digital cable box to the receiver and then back to the VCR but the digital cable box doesn't seem to switch back and forth between the S-Video and the RCA video, plus I'm not able to run the RCA audio from the digital cable box to the VCR because I need the RCA audio for the analog channels and are plugged into the RCA audio for Video 2. At this point I think I'm just rambling on but if anyone can provide some insight I'd greatly appreciate it. Thanks! |
#2 |
Polk Expert
Member Sales Rating: (17)
You need an RCA cable from the receiver Video 2 out to the VCR's input
__________________
Acurus RL11 - Preamp Aragon 8008ST - Power amp Sony DVP-NS999ES - SACD player ADS 1230 - Polk SDA 2B - Vandersteen 2Ci (8) 12" driver DIY - Subwoofer Crown K1 - Subwoofer amp Outlaw ICBM - crossover Beringher BFD - sub eq Where is the remote? Where is the $%#$% remote! "I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." |
#3 | |
Polkie
Quote:
__________________
32" Sony Wega Kenwood VR6070 Panasonic DVD-CV51 Polk Audio RM6200 Polk Audio PSW250 |
#4 |
Polk Guru
Member Sales Rating: (10)
OK,
here's what you do.I assume you have a Motorola Comcast digital box correct?(you will still receive the video and audio via S and Digital) Take the analog off the receiver(from the cablebox) and run it directly to the Vcr L1 in.Then run a composite run there as well. To record a channel from the cable box,you need to put the VCR on L1.Then set the channel on the cablebox to what you wanna record. Another easy way to get audio and video(worse way)is to run a coax line out of the cablebox to the ant/cbl in on the vcr.The hookup will need you to put the VCR's tuner to channel 3 or 4 whichever the cablebox is outputting on. Now the loop through your audio video receiver can be done as well.This requires all outs to the receiver(except the coax feed)into a input of your choice,then use the out's to get the signal to the vcr. Here's what I mean. Your using video 2 in on your receiver for cable.S-video,composite,digital and analog audio.Hook the VCR up to video 1,then use the video 1 out's back to the VCR.It will carry the Video 2 signals in analog(cablebox) back to the VCR via L1 input.Switch the receiver to video 2,switch the VCR to L1,set the cablebox to channel of choice,and your on your way to recording. Here's the best way to record............TiVo......yes TiVo,this is a hard disc recorder.It will record all of your favorite programs for you and you watch them when you want.Not when they air(unless you want to of course.No more Seting up the vcr,no more VCR PLUS,No more video tapes.........what more can you want??? I'd look into a TiVo series 2 recorder............TiVo your way my man.
__________________
Dan My personal quest is to save to world of bad audio, one thread at a time. Last edited by mantis; 02-11-2003 at 07:49 PM.. |
#5 |
Old School
Member Sales Rating: (1)
Oh what a tangled web we weave...
VT, What's occupying Video 1?
__________________
More later, Tour... SOPA-PIAS Taste Good "There is a certain entertainment value in ripping the occaisonal (sic) buttmunch..." - TroyD "Death doesn't come with a Uhaul" - Dennis Gardner "Life's been good to me so far" - J. Walsh Stripped down system flooded by Ike (thanks alot motherf----r) ... SDA CRS+ (floaters) - Carver C4 Pre (anchor) - Carver M4.0 (survivor by ~1") |
#6 |
Polk Guru
TiVo's got the "Big Brother" thing going on. It spies on you and I say EFF'EM!
__________________
'Political Correctness'.........defined "A doctrine fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end." President of Club Polk |
#7 | |
Polkie
Quote:
The only thing Video 1 is used for is VCR playback. So right now Video 1 is taking in the RCA audio for the VCR Audio out and then I have the Video out from the VCR directly to the TV. |
#8 |
Old School
Mantis, Is a week up yet? Cause if it is, I was wanted to ask you about upgrading his interconnects...
VTH, Really hard to picture the wiring, thus the tangled web comment. I think I know what hoosier and Mantis are driving at, but let me try from scratch. I’m not sure of the interconnect limitations you have. It sounds like you have S-Vid, coax and RCA on your AVR and cable box, and the VCR has only coax and RCA…. Yes? (The VCR likely has either component or composite video connections as well, but we’ll set that aside for now as you have not mentioned your video routing cause it’s working.) Next, are you sure the cable coax out is Digital audio, or is it Analog Video/audio? Put another way, is your AVR equipped to process/ decode a digital input? Even lacking this info with certainty I’m going to take a shot here. It sounds to me like you’re routing more cable inputs than you need to from the cable box to video 2. Your AVR is giving you three options for getting your signal to it from your source, in this case the cable box. You don’t have to use them all. Just use the best one. From best to worst the audio options are: digital co-ax, S-vid or RCA and analog coax.. Since both the S-Vid and coax are already carrying the audio and video from the cable box to the AVR, simply take the Cable box RCA out to the VCR in. Unless you record another source on your VCR, this should work for you. Try this first. And rest a minute, or a day, cause we’re going to get wild next… If you stop at the above I think you are underutilizing your AVR. You say you are routing your VCR video to the TV. You should not have to do this. With S-vid connection capability, your AVR can certainly route video signals as well as audio. I think for starters you should: -remove all of the V1, V2, VCR and Cable box interconnects: -route S-vid from the cable box to the AVR. So it’s cable S-vid out to AVR V2 in. -next route coax from VCR out to V1 in and then coax connect V1 out to VCR in. With this you are using Video One to "loop in” the VCR. You should now be able to select V1 to view/ hear a tape and select V2 for cable. And when you're on V2 the audio/video signal should be available from the AVR to the VCR for recording. The only thing left is getting any of your video sources out of the AVR to your TV. Somewhere on your AVR’s backside there’s a “Main Video Out” of some kind, maybe under a different name. It'll be coax, S-vid, composite or component. This is what should go to the TV, period. Your AVR should do all of the source switching for audio and video. The quality batting order for video from best to worst is Component RCA, S-vid, Composite RCA and coax. Again for now run S-vid if both the AVR and TV have S-vid connections. If they don’t, then run coax. Get this “simple” set up working first and then you can substitute, not add… substitute in better connections to upgrade quality. Post whether this works and then we can figure out the next steps if you need further assistance. |
#9 | |
Polkie
Quote:
#10 | |
Polkazoid
Quote:
Now most of the digital video signal is also protected by macrovision and most VCRs tuner will be affected by this unless you have one of the anti-macrovision to connect between your digital box and your VCR. |
#11 |
Polkateer
Read your problem.....but didn't really read responses. I'm sure your Digi-Cable box has some menu asking if you want to use digital output (and I'm assuming you chose this option). VCR's record via stereo input (rca composites). You probably need to choose standard stereo out in your cable box to get audio to your VCR. I've experienced this problem w/ DVD to VCR recording. Good luck.
__________________
Home Speakers polkaudio [size=2.5]RTi70's (bi-wired), CSi30, FX3000i, PSW250[/size] Car speakers polkaudio [size=2.5] EX 369, DB 650 [/size] |
#12 |
Polkie
Ok, time for some clarification.
So if I were to switch to the following setup, would I cover all my bases?: Digital Cable Box to Receiver S-Video Out -> S-Video In (Video 2) Coax Digital Audio Out -> Coax Digital Audio In (Video 2) Digital Cable Box to VCR Composite Video Out -> Composite Video In RCA Audio Out -> RCA Audio In VCR to Receiver Composite Video Out -> Composite Video In (Video 1) RCA Audio Out -> RCA Audio In (Video 1) Receiver to VCR/TV S-Video Out (Monitor Out) ->S-Video In (TV) Composite Video Out (Monitor Out) -> Composite Video In (TV) RCA Audio Out (Video 1) -> RCA Audio In (VCR) I'm not including the DVD and PS2 setup because those are working without any problems. Both are using Optical Audio, the PS2 is using S-Video and the DVD player is using Component Video. My biggest concern is with the Coax Digital Audio from the Digital Cable box being able to carry the Analog audio for channels 2 - 75 (Basic Cable). If it does, then the setup above should work, or at least I think it would work. |
#13 |
Polkazoid
You shouldn't hook up or use the composite video connection (parallel with S-video) at all, just connect one of the S-video out from your receiver to your VCR (to record), toss out all of the composite video connections. If your digital cable box always has the signal on the analog (RCA) audio out, then everything should work, if not, you don't have sound but picture on when you're recording on your VCR since your VCR can not record digital audio signal.
#14 | |
Polkie
Quote:
#15 |
Polkazoid
No you're not, but check with the manual of your receiver, if the receiver outputs both S-video and composite video signals when you do the parallel hook up, if it does then you're in good shape. I didn't know your VCR is a non S-VHS model. Try it the way you describe and post here if you have any problem.
#17 | ||
Old School
Color blind... "pink carpet"...
Quote:
Actually "my offer" didn't even apply to interconnects. Within reason, I'm actually a proponent of better cabling there. |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
