| Register | System Showcase | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#1 |
Member Sales Rating: (32)
Guys,
TT makes a great product. It was packaged exceptionally well and arrived on time. The pictures speak for themselves. My records are completely flat. I haven't done much critical listening yet, but my first impressions are promising. The two instruments fit on my TT without issue and performed as described. |
#3 |
Member Sales Rating: (12)
I must say it looks pretty cool on your table.
__________________
2 Ch Rig VPI HW 19 Mk IV TNT Platter & plinth SAMA The Clamp SME Series V arm Black Diamond Racing Cones VPI 16.5 record cleaning ZYX R1000 Airy 3B Silver Base cart K&K MC LL9206 Step-Up xformer Spectral DMC 10G phono pre Signal Cable MagicPower Raysonic CD168 Denon 2900 SACD/DVD-A MF Tube Buffer Musical Fidelity Tri Vista 300 Polk SDA/SRS 1.2 TL RD0198 Bi-wired Xovers w/Sonic Caps & Mills MIT Shotgun S3 ICs MIT MH 750 Shotgun Bi-Wire Monster HTS 5100 MKII Isol Pads |
#4 |
Member Sales Rating: (11)
Looks nice.
How does an outer ring clamp work? Is it actually clamping to anything...or is it basically a weight?
__________________
The nirvana inducer- APC H10 Power Conditioner Denon DVD-2910 universal player DPA The Little Bit Three DAC Yamaha P-300 turntable/TCC TC-750 phono preamp Acurus L10 preamp Adcom GFA-545 power amp PolkAudio SDA 2A's/PolkAudio Monitor 7A's Audioquest Type 4 speaker cables Audioquest Sidewinder IC's Audioquest Black Mamba IC's Signal Cable Analog II IC's |
#5 |
Member Sales Rating: (15)
Here are some links for more info.
http://www.ttweights.com/TTOuterring.html http://www.ttweights.com/Periphery.html http://www.youtube.com/watch?v=XnzDGGAmtDo
__________________
Does anybody remember laughter? Last edited by Keiko; 03-27-2009 at 07:09 PM.. |
#6 |
Just wrote this up a half hour ago. Sorry if there are any grammar or spelling errors.
Review of the TTWeight: TT Outer Ring and TTMiddleWeight Let’s face it; sometimes the high-end requires an audiophile to purchase a piece of equipment blindly. This virtual cliff jumping may destroy the synergy of your system, but the potential exists to take your rig to a new degree of enjoyment. Feeling daring one evening, I clicked the “send payment” button and purchased a TTOuter Ring and TTMiddleWeight record coupling system. The 600 Gram TTOuter Ring Lists for $ 299 and includes the TTConcentricity Disk. The 1050 Gram TTMiddleWeight Lists for $64.99. Both units were very well packed. The TTOuter Ring arrived in a wood crate, while the TTMiddleWeight was packed in a separate set of padded boxes. Shipping via UPS 3-day Delivery amounted to $ 35.00. My initial total was $ 398.99, but Larry Denham of TTWeights gave me 25% off the TTMiddleWeight and knocked $ 20.00 off the TTOuter Ring. After special discounts, my total was $365.99 – a veritable bargain considering other competitors list periphery ring clamp solutions from $600 to $1,500. To ease the apprehension that I may have just blown some serious change on scrap metal, Larry Denham insures his products with a 100% money back guarantee if not happy. After unscrewing and razor-blading through the layers of packaging, most audiophiles are ecstatic to finally hold in their hands an artistic piece of aural engineering. This was partially true for me. The TTMiddleWeight and TTOuter Ring are beautifully crafted with fine precision edges that are awe-inspiring. However, the weight of these two instruments was unexpected, and I cringed at the idea of putting what felt so heavy on my delicate Pro-ject RM-5 SE. Sure I knew their technical specs before buying them, but does anyone in the United States really know what 600 or 1050 grams feels like? The TTOuter Ring and TTMiddleWeight combined weigh as much as 291 copper-nickel quarters minted after 1964. That’s $72.75! You’d have to eat three standard foot-long Subway Club sandwiches to increase your body-weight by the poundage of the TTWeight decoupling system. Finally, next time you are in Miami and see a hot blond with twin 660cc non-silicone breast implants (a.k.a. “Double Ds “) walking past you, remember those fun bags weigh nearly half a pound less that the TTWeight gear. To begin testing, I listened to several records in near mint condition and several with inner and outer warping issues. Each record was listened to all the way through with nothing but the stock Pro-ject screw-down puck on the TT. Then, I replaced the stock puck with the TTWeight coupling system and repeated the listening session. Installation was fairly simple, however, the TTCentricity Disk would not clear the stylus of my Pro-ject while the tonearm was locked in the “Tonearm rest.” No problem here; I just moved the tonearm from its resting position and gently set it outside the “tonearm rest” to an angle where the TTCentricity could slide gently in and place the TTOuter Ring on the record below. The TTCentricity worked like a charm and the ring sat perfectly centered and even around the edges of the record. Next I simply placed the TTMiddleWeight on the spindle – no screw-down necessary, just be careful not to drop the damn thing as the scene would be much akin to throwing a small aerobics weight at your turntable. The concave base of the TTMiddleWeight sat comfortably on the LP, and presumably focused its pressure around the edges of the record’s labeling to optimize contact with the record and platter. “Click,” I flipped the switch and held my breath wondering if the motor in my turntable could muster the strength to spin the weight sitting upon it. With relief I took a breath as the platter began spinning with the same ease as it always has. The stylus cleared the inner rim of the TTOuter Ring with room to spare. The TTWeight record coupling system was a stellar improvement with perfect and less than perfect LPs. My notes across the board indicate a wider more transparent soundstage with better imaging and overall instrument placement. I’m sure this has something to do with the fact that even at eye level with the TTOuter Ring spinning, it was impossible to see any warping on even my most weathered LPs. The TTWeights flattened the vinyl exceedingly well. One LP in particular that had a wicked warp, despite being purchased new, was notorious for hissing and distortion during the higher notes of all songs. With the TTWeights in place, these imperfections vanished as the stylus floated gently through the grooves. Seriously, that’s just amazing. The space between tracks and softer songs were much quieter as the sound of the stylus over the record was all but a warm and welcoming hum. Overall, the performance from each record was more natural with greater detail and accuracy, which ultimately translated into a virtually un-fatiguing, lush and utterly live musical performance. I can’t help but love my new copper TTOuter Ring accompanied by its companion solid brass TTMiddleWeight. The TTWeights are not cheap, but they’re still a bargain worth their weight in gold. Last edited by SolidSqual; 03-29-2009 at 11:31 PM.. |
#8 |
Member Sales Rating: (0)
Glad to see the ring and center weight arrived safely. I like the shipping packaging for the ring; much better than a box could ever protect it. To give you some perspective, the VPI ring is almost 2200 grams. With the ring in place, I always help start the platter rotating as I use silk thread as a belt. As you found, the sonic characteristics improve with the periphery clamp in place. I will always user some mechanism to clamp the exterior and center of the record because of this.
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Periphery Ring Clamp? | SolidSqual | 2 Channel Audio | 26 | 03-19-2009 01:56 PM |
| FYI TT Periphery Ring Clamps | jm1 | 2 Channel Audio | 19 | 03-09-2009 08:17 AM |
| Polk MM8 outer diameter? | GLN305 | Car Subwoofer Talk | 20 | 01-10-2008 10:30 AM |
| The Clamp: reflex record clamp | hearingimpared | For Sale (FS) Classifieds | 6 | 07-23-2007 11:56 PM |
| Outer Diameter for Polk dB 12 | GLN305 | Car Audio & Electronics | 6 | 02-12-2007 05:36 PM |
