Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 02-16-2003, 11:37 PM   #1
thehalo8
Polkster
Member Sales Rating: (0)
Send a message via AIM to thehalo8
Default Wiring my CSi40
I just picked up the CSi40 that I have had my eye for some time now. I will eventually bi-wire it, but for right now I just want to hook it up and enjoy.
I have looked through many past posts and was unable to find another thread already discussing my question. I know if I want to bi-wire that I must take off the metal jumpers to keep from possibly harming my speaker. But does it matter which terminal I connect the wire to when the metal jumper is on? I would assume either the top or the bottom terminals would be fine since they will share through the jumper. If someone could let me know if it matters or not I would really appreciate it. Thanks.
Mike
__________________
Mains: Polk RTi70's
Center: Polk CSi40
Surrounds: Polk TC60i's
Sub: Polk PSW505
Receiver: Onkyo TX-DS696
TV: Samsung HLS 5687W 56"
DVD: Sony DVP S5300
Protection: Monster HTS 3600
Backup Battery: Belkin AP3080010
thehalo8 is offline   Reply With Quote
Old 02-17-2003, 02:42 AM   #2
danger boy
Polk Guru
Member Sales Rating: (10)
Default
does not matter. you are correct you can connect to either top or bottom. i flip a coin.. that's how i decide. ha ha ha heads top, tails bottom.
__________________
I need a new sig...
"Ask not what can your stereo system can do for you, ask what you can do for your stereo"
- little ol me
danger boy is offline   Reply With Quote
Old 02-17-2003, 02:47 AM   #3
HBombToo
Polk Master
Member Sales Rating: (1)
Send a message via AIM to HBombToo
Default
If you have some additional speaker wire you might want to try and remove the flat terminal straps and replace them with the wire.
HBomb
__________________
***WAREMTAE***
HBombToo is offline   Reply With Quote
Old 02-17-2003, 10:56 AM   #4
mantis
Polk Guru
Send a message via AIM to mantis
Default
Whatever kind of wire you use for your mains should be the kind of wire you should use for your center.
Replacing the jumpers with the same wire is a good direction.Bi wire is the best.
__________________
Dan
mantis is offline   Reply With Quote
Old 02-18-2003, 12:50 PM   #5
thehalo8
Polkster
Default
Thanks for the quick replies. I chose the top terminals to connect the wire for now, and I am very pleased with it. I am using the same wire for all speakers throughout my system. I do not have anymore wire, so that is why I did not bi-wire my center channel. I just used the wire I was using on my old center channel. I plan on buying some more wire soon. How much of a difference does the bi-wiring actually do? I read posts about how it sounds better, but how much does it actually improve the sounds?
Old 02-18-2003, 01:37 PM   #6
kberg
Polkazoid
Default
Quote:
You'll get different answers to this question, ranging from "a world of difference" to "I can't tell the difference".
Bottom line: Try it and let your ears decide.
__________________
Mains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688
kberg is offline   Reply With Quote
Old 02-18-2003, 04:20 PM   #7
danger boy
Polk Guru
Default
you'll get a slight improvement in sound if you bi wire.. but like kberg said.. it's different with everyone. I found mine didn't sound louder or anything.. what I noticed was the sound to be more open and airy. fluffier, softer, warm and fuzzy-ier.
Old 02-19-2003, 03:14 AM   #8
Tour2ma
Old School
Default Re: Wiring my CSi40
Mike
True for bi-amp; Not true for bi-wire...
__________________
More later,
Tour...
SOPA-PIAS Taste Good
"Death doesn't come with a Uhaul" - Dennis Gardner
"Life's been good to me so far" - J. Walsh
Stripped down system flooded by Ike (thanks alot motherf----r) ...
SDA CRS+ (floaters) - Carver C4 Pre (anchor) - Carver M4.0 (survivor by ~1")
Tour2ma is offline   Reply With Quote
Old 02-19-2003, 07:48 AM   #9
Dr. Spec
Polk Expert
Default Re: Re: Wiring my CSi40
Quote:
It is a good idea though, and failing to do so negates the purposes of bi-wiring, which is to eliminate cross talk between the terminals.
__________________
Ed Mullen
Customer Service Director / Product Development Manager
SV Sound International
www.svsound.com
sales@svsound.com
techsupport@svsound.com
LSi-7
F/X 1000
CS245i
Dr. Spec is offline   Reply With Quote
Old 02-19-2003, 11:16 AM   #10
Tour2ma
Old School
Default
Agreed Doc, I was just saying that speaker damage is not the reason.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
