Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 03-02-2003, 05:11 PM   #1
hamzahsh
Polkateer
Member Sales Rating: (0)
Question Accessory to connect to speaker wires!
What kind of accessory do I need to hook two speaker wires. I'm using 16 AWG Acoustic Research Speaker wire for my Polk Audio speakers. I like the idea of bi-wiring but they are very hard to get into the Banana plugs of my receiver.
I need some kind of interconnect so I can put two wires and then connect that into my receiver's banana plug.
Please tell me what its look like and where can I buy it.
Thanks for the help
__________________
Panasonic TH-50PX80U Plasma HDTV
Polk Audio RT800i (fronts)
Polk Audio CS400i (center)
Polk Audio F/X1000 (side surrounds)
Polk Audio RTi6 (back surrrounds)
Velodyne CHT-15 (subwoofer)
Yamaha RX-V1400 (Pre/Pro)
NAD C272 (2-ch Amp)
Adcom GFA-7605 (5-ch Amp)
Toshiba SD-3109 (DVD/CD player)
Malata DVP-580 (Multi-region DVD player)
hamzahsh is offline   Reply With Quote
Old 03-02-2003, 05:30 PM   #2
polkatese
Polk Master
Member Sales Rating: (10)
Send a message via Yahoo to polkatese
Default
try here:
http://www.partsexpress.com/pe/showd..._ID=2462&DID=7
I had the same problem before, and this kind of banana plug allows you to fit in two run of speaker cables, twisted the wire, and secure them thru the openings, and tighten the screw. It works for me, hope it helps...
__________________
Connoisseur of obsolete audio: Laser-Disc, DVD-Audio, HD-DVD, Dual-Disc
polkatese is offline   Reply With Quote
Old 03-02-2003, 09:45 PM   #3
mantis
Polk Guru
Send a message via AIM to mantis
Default
umm no
receivers don't have banana plugs but most except them.What you have is called binding posts,some receiver even have 5 way binding posts, but most do not.
Moster makes screw on banana plugs that will easily except the wire you own.
Radio shack also has nice banana ends for bi wire and any other wire configuration you wanna make.
__________________
Dan
mantis is offline   Reply With Quote
Old 03-03-2003, 12:40 AM   #4
gidrah
Polkologist
Member Sales Rating: (1)
Send a message via Yahoo to gidrah
Default
Yep to the Radio Shack. In fact I was just putting some on a set of cables. I think I paid $5.99 for each set. They'll accept up to 10 AWG.
__________________
Make it Funky!
gidrah is offline   Reply With Quote
Old 03-03-2003, 12:22 PM   #5
hamzahsh
Polkateer
Default
Actually I have binding posts on my receiver! not banana plugs.
Old 03-07-2003, 11:07 PM   #6
Tour2ma
Old School
Default
OK... and the holes in the amp's binding posts are so small that they cannot accept two 16 gauge ends twisted together???
__________________
More later,
Tour...
SOPA-PIAS Taste Good
"Death doesn't come with a Uhaul" - Dennis Gardner
"Life's been good to me so far" - J. Walsh
Stripped down system flooded by Ike (thanks alot motherf----r) ...
SDA CRS+ (floaters) - Carver C4 Pre (anchor) - Carver M4.0 (survivor by ~1")
Tour2ma is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
