Go Back   Club Polk > On the Move > Car Audio & Electronics
Reply
Thread Tools
Old 03-06-2003, 12:17 PM   #1
Colin_S
Guest
Posts: n/a
Default Active Crossover
Can anyone recommend what active crossover i should use to bi-wire a set of mm465s and two mm120s? I need the crossover to have 3 RCA inputs so as my DAC/Time Alignment will work to its best.
Colin
Old 03-06-2003, 01:50 PM   #2
PoweredByDodge
Polk Expert
Member Sales Rating: (0)
Send a message via AIM to PoweredByDodge
Default
3 pair of inputs (3 left + 3 right) or 3 inputs ( left, right, and other left or another right) ?
__________________
"Well a gypsy lady once told me, 'Son you got the kinda soul that's got to be free. It ain't whatcha want, it's just what you need. Like a blackbird baby you were born with wings." --- Gary Allan.
Vince Spinelli
-- "Kinda off his mental reservation."
www.SpinelliCreations.com
blog.SpinelliCreations.com
Vince@SpinelliCreations.com
Bizzazop...
PoweredByDodge is offline   Reply With Quote
Old 03-06-2003, 04:03 PM   #3
automaticman
Polkie
Default
I'm sure he means 3 pairs of inputs. I haven't seen that many x-overs with that, I know Coustic makes one ( i can't remember the model number) and there's the Audiocontrol 6XS - which is a very nice piece, but it uses resistor packs to set the x-over points so it takes a little more work to set up.
automaticman is offline   Reply With Quote
Old 03-06-2003, 05:08 PM   #4
Colin_S
Guest
Posts: n/a
Default
Yea Buddy 3 pairs of RCA inputs. I have Time Alignment straight before it so if it didn't use 3 pairs of RCA inputs i would lose that. I had an AudioBahn one which i just sold. It just wasn't good enough for what i needed. The problem with Audio Control is i am in the UK and no one imports them here so the modules are hard to come across.
I want the Nakamichi EC-302 but i can't find one anywhere, and think it might be a bit expensive. Well there is one on E-bay in Germany but he is selling it with loads of other stuff and wont split.
Old 03-06-2003, 10:47 PM   #5
Josh
Polk Installer
Default
One option is to get amps with built in crossovers with a x20 switch. Alpine's MRV-F540 can be used with a set of MM6's with a single set of stereo inputs to run all 4 channels. You can use channels 1,2 for the mids which can be bandpassed, and use the other two channels for the tweeters and high pass them. We have done a couple of setups like this and it works great.
Josh is offline   Reply With Quote
Old 03-07-2003, 12:47 PM   #6
automaticman
Polkie
Default
What do you recommend is a good x-over point / slope for a pair of MM6 run active?
Old 03-07-2003, 06:04 PM   #7
Josh
Polk Installer
Default
I would run the mids at 55-3k and the tweeters high-passsed at 3.5k. That's just a starting point. You can fine tune from there.
Old 03-13-2003, 09:26 AM   #8
Colin_S
Guest
Posts: n/a
Default
Thanks, that's some good info. I have just got a Sony XEC-1000 which I'm going to use until i get a XDP-4000x.
What would you suggest the RMS power rating for the tweeters and mids separately are for a MM465 system?
Also any info on the Momo 8" sub that will be released? When will it be released, what will the RMS power be, what will be the mounting depth? I am hoping to mount this in the Doors with my MM465. Will the 8" be the smallest or will a 6" sub be available?
Cheers all!!!
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
