Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 03-10-2003, 07:50 PM   #1
kapila
Polkie
Member Sales Rating: (0)
Default Lsi 25 placement
Can a Lsi 25 be placed a few inches from a wall or wooden shelf with the subwoofer placing the wall ? Will this damage the subwoofer?
kapila is offline   Reply With Quote
Old 03-10-2003, 07:58 PM   #2
phuz
Polkologist
Member Sales Rating: (4)
Send a message via AIM to phuz Send a message via Yahoo to phuz
Default
I'm not exactly sure what you mean. Do you mean a few inches from a wall with the sub facing the wall? If so, it won't damage the sub but I don't think it would make for optimal sound quality.
phuz is offline   Reply With Quote
Old 03-10-2003, 08:13 PM   #3
RuSsMaN
Hardcore
Member Sales Rating: (27)
Send a message via AIM to RuSsMaN
Default
From my experience with the LSi15, a good 2 feet from back/side walls seemed optimum. Really solidified the stereo image.
With the sub a few inches from the wall, you should notice a 'boomy' factor, but that may suit your tastes. Experiment, and report back.
Cheers,
Rooster
__________________
If you're gonna be dumb, you gotta be tough - when you get knocked down, you gotta get back up - Roger Alan Wade
RuSsMaN is offline   Reply With Quote
Old 03-10-2003, 10:00 PM   #4
mantis
Polk Guru
Member Sales Rating: (10)
Send a message via AIM to mantis
Default
kapila,
I assume you have space issues?There are suttle things you can do to avoid this.....and to answer your question,I agree with the last 2 posts.I wouldn't do it.
To get out of what you paid for them,you might want to reconsider where your going to place them.Less then Ideal rooms create big challenges for big speakers.
I would like more input,maybe a pic of the room and I could try to help you further.
__________________
Dan
mantis is online now   Reply With Quote
Old 03-29-2003, 08:41 PM   #5
Apex
Polkster
Default
If you do have to put them by the wall.I'd set them to small so you wont have as much boom.Try even playing with the phase.
__________________
H/K AVR7000
"LSI25's bi-wired with 2.4s
Mirage OM c2 Center "LSiC soon"
FX300i rears "LSi15's soon for the rears".
Apex is offline   Reply With Quote
Old 03-30-2003, 07:29 AM   #6
mantis
Polk Guru
Default
Quote:
Well I see where your going with this but I feel if this is a nessary step and there's nowhere else to place these beautiful speakers,I feel the wrong speakers where choosen.You would be better off returning them and gettin the Lsi9's on high quality stands.Then I would upgrade the current sub to a better more musical sub like the REL StormIII.
The problem which I run into quite often is that many people buy killer speakers and put them into a room where they have no chance of performing.I find this a waste of money and a lack of planning.With alittle thought,you can get the speakersthat will perform there best(or at least better then monster floorstands stuffed in somewhere).
If you get offended by what I wrote here,don't you not alone at all.This is a very common mistake and has been also made by myself.If you don't think the room has a big/huge/enormous effect on your sound quality,your wrong.
Picking speakers that might not be as MANLY and getting the smaller more WIMPY,will perform better in given enviroments.
This sounds like the speakers need to be rethinked.......good luck.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
