Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 03-18-2003, 01:32 PM   #1
tryrrthg
Polkhead
Member Sales Rating: (11)
Question Kimber Cable (4PR) terminations?
I just scored a brand new 10 foot pair of Kimber 4PR speaker wire on audiogon for $20. They are unterminated and I would like to terminate them. My question is what should I use? Banana or spades? I would like to keep the cost under $20 or so for all 4 connectors. I have Dynaudio 1.3mkII speakers. they have WBT binding posts, so I'm not sure what size spade or bananas they will take (mabye Mantis can help me out here?).
Also where can I get them? Audio advisor has these but they're shipping charges are outrageous for four little connectors!
http://www.audioadvisor.com/store/pr...et%20of%20Four
I don't have access to a soldering iron so I'd prefer some solderless connectors... I've been surching all morning and haven't found much...
Any help would be greatly appreciated!
tryrrthg is offline   Reply With Quote
Old 03-18-2003, 10:46 PM   #2
mantis
Polk Guru
Member Sales Rating: (10)
Send a message via AIM to mantis
Default
tryrrthg,
thats a good price on 4pr kimber.You know that 4pr was/is there very first built Kimberkable wire?t's as ugly of a color wire as I have ever seen.But good performance is what Kimber is all about.
Now owning the Dynaudio 1.3's well I think you undershot your wire just a bit.Just to let you know with those speakers you should have Monocle X premade 2 conductor wire.If bulk is your game then 8tc would be the perferred choice.
Since you scored a good deal here,lets roll on that and get you into the correct ends.You have 2 choices as I see it.Soder is not nessary when I nstalling Kimber ends.The Spades for your speakers are PM-25's.They are a crimp on with a heat shrink tube.You'll need a heat gun or a lighter to shrink the tubing.
Now to match your binding posts on the Dynaudios,I would use the Sandwich Spade made by WBT which is a screw on locking end.#5108320.Standard 1/4 inch is all thats needed.
Price????spend the money man,your speakers and the saving you saved from the wire purchase(which is way under the level of your speakers)you should feel free to drop the nessary cash to terminate the wires correctly.
__________________
Dan
mantis is offline   Reply With Quote
Old 03-19-2003, 09:28 AM   #3
tryrrthg
Polkhead
Default
thanks mantis!
I'm only using this wire to "get me by" I spent my last dime on these speakers (got them used for less than half the price of a new pair and they're only 5 months old). I'm saving up for a good amp. Currently I have a $300 yamaha receiver driving them because I can't afford an amp at the moment (damn engagement ring!). So the Kimber will be a needed step up from the 12ga Home Depot wire I've got now.
I'm planning on some better wire in the future but don't ever plan on going much more than 150 bucks (used). I can't justify spending that kind of cash on wire... I'd rather spend the money on room treatments or gear that will make a more significant difference/upgrade...
Any suggestions for an pre/amp combo, or integrated for around $1000-1500 (used of course)? I've been eyeing the Arcam A85 for a while now. There is a great review of the Arcam that they used the 1.3mkII as the speakers:
http://www.soundstage.com/revequip/arcam_a85.htm
I also like the reviews of McCormack gear. Thought about a Krell KAV300i but heard a lot of QC issues (blown fuses etc), and I've never heard Krell before. The shop here never has any on display.
I don't really crank it up too much so a lot of watts aren't all that important but I do like to get them thumping pretty good! And boy do they THUMP for such a little speaker!
__________________
The Had My First Child, Have To "Give Up" My Stereo Room, Condensed Two Channel & HT Rig:
Mains: Dynaudio Focus 140 Integrated Amp: Arcam A85 Source: Slim Devices Squeezebox 3 -> Bel Canto DAC 1.1
Home Theater: Sony KDL-40V2500 HDTV, Sony BDP-S550 Blu-ray, Polk CSi3 & R15, Denon 2802 receiver, and DIY sub with Atlas 15
Old 03-19-2003, 11:17 PM   #4
mantis
Polk Guru
Default
I can't say this enough ...Matching Bro matching.You have one of the very best bookshelf speakers ever made.You really should look into Mark Levinston or Krell.
Now I see the Price you wanna spend and I know Rotel sound good with Dynaudio.
I would look into Rotels Rc1070 and the RB1080.This should give you a good entry level seperates for your Amazing speakers.
Wire I"m sure The 4pr Kimbers destroy the tonal quality of the Home Depot wire........thats a really big step forward.Get the spades,you'll be happy.
Good luck my man......let me know how you make out.
Old 03-20-2003, 12:09 AM   #5
Zero
Stronzo
Member Sales Rating: (4)
Send a message via AIM to Zero
Default
Man - Dynaudio 3Mk.2 bookshelves!!! Good Loward.. I agree fully with Dan.
Match it man - ! If you cannot afford Mark or Krell - go with Musical Fedility. Crushes Rotel as far as Im concerned, and only costs a bit more.
Look into the A3.2 integrated with the cd player....... it's a winner for sure.
Zero is offline   Reply With Quote
Old 03-20-2003, 08:25 AM   #6
mantis
Polk Guru
Default
ATC,
good points but homey don't wana spend the dough......he should but It doesn't seem willing.
Rotel is the cheap alternative and Proven with Dynaudio.Musical Fidelity is great stuff but not proven with Dynaudio.Listen and see.
Old 03-20-2003, 09:07 AM   #7
tryrrthg
Polkhead
Default
I know that I should spend the cash, but wanting to and being able to are two different things. And I can get a WHOLE lot of amp for $1500 used! I'm getting married in the fall so any extra cash doesn't exist at the moment. The better half says I MIGHT get some of the wedding money to buy a new toy! one can only hope!
I got a steal on the Dyn's that I couldn't pass up ($1200, and they're 5 months old). A friend of mine has the Dynaudio 1.3SE and he gets pretty good results with NAD silver series which is not all that expensive.
I've heard the Arcam A85 with the Dyn 1.8mkII and it was a pretty nice combo. If I go with Arcam I'd like to step it up the the new FMJ A32 but I never see them on the used market. Read the review I linked in my first post. The Arcam and the Dyn 1.3mkII is a killer combo. I do have my eye on the Krell integrated but I don't have anywhere to audition so I'd have to buy it and then sell it if I didn't like it (although I'm sure I wouldn't have trouble selling). McCormack is no slouch either.
Mantis, ever heard Pass Labs and Dyns? I've looked into the Aelph 3 or Aelph 30 also. low watts but pure class A...
Old 03-20-2003, 10:04 PM   #8
mantis
Polk Guru
Default
No I haven't.
Dynaudio speakers in general are very flexable but are a 4 ohm load.Getting married huh.........cool.
Old 03-21-2003, 02:06 AM   #9
gidrah
Polkologist
Member Sales Rating: (1)
Send a message via Yahoo to gidrah
Default
Great speakers man!
Are you opposed to bare-wiring for any particular reason?
I've found the Kimber spades mentioned, but @ 16.50/pair + S/H. I honestly doubt there would be a noticable difference between these and Radio Shack spades @ $8 (or so) for 4 pr.
Then again I usually try my best to stick with bare wire. More surface area, better bite, cheaper, etc. The squirrel goes down the tree, runs around twice, and gets smashed at the bottom. Nail clippers clean up any residue.
__________________
Make it Funky!
gidrah is offline   Reply With Quote
Old 03-21-2003, 09:28 AM   #10
tryrrthg
Polkhead
Default
I'm not opposed to bare wiring, I just thought I'd prevent some oxidation, and spades are easier to work with.
Since the wire was so cheap I thought I'd spend a little more for some terminations. I should probably just put the extra cash in my amp fund!
I'm SO HAPPY with my speakers now! I can't wait to get some REAL juice behind them. I told my fiance last night that owning my speakers without a good amp is like going to Italy and sitting in your hotel room all day looking out the window (she likes to travel). She didn't think that analogy was a very good one, but I thought it was perfect!
Thanks for the help guys!
Old 03-21-2003, 10:16 PM   #11
mantis
Polk Guru
Default
I think you hit it right on the nose my man.......
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
