Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 04-02-2003, 03:33 PM   #1
ndestruckt
Polkie
Member Sales Rating: (0)
Default Speaker A & B
Hello Fellow Members,
I have a question, can I use both speaker A and B at the same time? What are the disadvatage and advantages?
Sonny
ndestruckt is offline   Reply With Quote
Old 04-02-2003, 04:41 PM   #2
F1nut
Polk Guru
Member Sales Rating: (10)
Default
1.Yes, you can.
2.Stress on the receiver.
3.You can play two pairs of speakers at the same time.
You'd be much better off playing A or B, but not together.
__________________
'Political Correctness'.........defined
"A doctrine fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
F1nut is offline   Reply With Quote
Old 04-03-2003, 11:33 AM   #3
BeginnersLuck
Polkster
Default
When you play A and B together, the receiver see a parallel load on its end. For example, if you have an 8 ohm load on terminal A and an 8 ohm load on B and you play them at the same time...the receiver needs to drive a 4 ohm load. Therefore, if you have two 4 ohm loads connected to terminals A and B respectively...then the receiver is driving a 2 ohm load. Most receivers that have A and B terminals do not recommend driving two 4 ohm loads at the same time becasue most receivers cannot drive a 2 ohm load.
So be very careful not to ask too much from your receiver...you could bring it to its knees.
-BL
__________________
TWFTPQ
Receiver: Outlaw 1050
Amps: Outlaw M-200 x 3 (Powering Mains and Center)
Mains: RT800i; Center: CS400i; Surrounds: F/X500i
Sub1: 214L Vented Tempest
Sub2: 122L Sealed Tempest
BeginnersLuck is offline   Reply With Quote
Old 04-03-2003, 11:23 PM   #4
mantis
Polk Guru
Send a message via AIM to mantis
Default
Speaker A and B............Yamaha's reasons for offering it today.
You can drive your home theater speakers off of the A channel and your stereo 2 channel speakers off the B channel.
So when your using the Home theater side,B is off.When listening to music in 2 channel A is off as well as the Effect........
If anyone's into Yamaha.
__________________
Dan
mantis is offline   Reply With Quote
Old 04-04-2003, 10:40 AM   #5
gidrah
Polkologist
Member Sales Rating: (1)
Send a message via Yahoo to gidrah
Default
Make sure to ventilate well and check your receiver to see how hot it is. Most higher quality receivers/amps can handle this load depending on the speakers connected and power (volume) applied. If you have a sub, set the x-over as high as possible.
__________________
Make it Funky!
gidrah is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
