Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 04-03-2003, 11:50 PM   #1
glennsmga
Polkie
Member Sales Rating: (0)
Default AMR50 problem
Hi. I have a set of Polk AMR50 computer speakers. There is a cable that runs from the soundcard to the speakers. The plugs have light green ends. When I plug the green ended plug all the way into the subwoofer, I only get sound from one of the 2 satellite speakers. When I pull the green plug slightly out of the subwoofer, both satellite speakers work. There is obviously something wrong here. Anyone have any ideas? Thanks! Glenn
glennsmga is offline   Reply With Quote
Old 04-03-2003, 11:59 PM   #2
dorokusai
Hardcore
Member Sales Rating: (41)
Send a message via AIM to dorokusai Send a message via Yahoo to dorokusai
Default
Plug the speakers into a Walkman or CD Player, see if they both play. If they do not, then you probably have a short. If they do, then the subwoofer end is the likely problem, and the short is probably behind the connector. Just a guess. I had a similar issue with a pair of headphones that "magically" went away after furiously plugging it in about 10 times. I don't recommend that as a fix,
__________________
Death is my set, guess my religion
dorokusai is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
