Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 04-11-2003, 03:50 AM   #1
eulogyt00l
Polkie
Member Sales Rating: (0)
Question I do not understand Bi-Wiring
I just got the LSI series and I've heard some thing about "bi-wiring" Improving sound quality. And I want to try it out but I don't know how. I know the Speakers have 2 speaker wire input terminals but, I only see one hookup teminal on the back of my Denon receiver. It says on Denon's FAQ page that there are separate terminals for bi-wiring and it also says most recievers have these "seperate terminals" on Polk's faq page. So from what I understand bi-wiring is just adding another single speaker wire for the low's by using 1 pair of speaker wire on a speaker in the 2 jacks instead of just a single wire in one jack. So if I am right, my question is where is the extra wire supposed to hook up on my receiver? As you might be able to tell, I am kinda new to home theater so any and all advice is greatly appreciated. Thanks!
__________________
Our Fathers are models for God. If our fathers bailed, what does that tell you about God?
--Tyler Durder--
eulogyt00l is offline   Reply With Quote
Old 04-11-2003, 04:32 AM   #2
F1nut
Polk Guru
Member Sales Rating: (10)
Default
Welcome to the forum.
To do this right, you should first purchase speaker cable made for bi-wire applications. At the amp end of one cable it will have two wires (positive & negative) that you connect to the Pos. & Neg. posts for the right channel of the amp. At the other end of the same speaker cable will be four wires, two of which should be marked "LOW" and two of which should be marked "HIGH." You connect the "LOW" Pos. & Neg. to the bottom Pos. & Neg. posts on the speaker. You connect the "HIGH" Pos. & Neg. to the top Pos. & Neg. posts on the speaker. IMPORTANT: You must remove the jumpers between the top & bottom speaker posts before you can bi-wire. Repeat the above hook up for the left channel. You are now bi-wired. There are no special posts on the back of any amp for bi-wire connections, you use the same posts as you're using now.
If any of this is still unclear, please say so and I'll try to help.
F1
BTW, you will find that the LSi's will really sing with a "high current" amp that can drive a four ohm load.
__________________
'Political Correctness'.........defined
"A doctrine fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
F1nut is offline   Reply With Quote
Old 04-11-2003, 04:32 AM   #3
gidrah
Polkologist
Member Sales Rating: (1)
Send a message via Yahoo to gidrah
Default
First post reward first reply. Welcome to the Forum. That appears to have the makings of a real nice system too.
Bi-wiring options:
1. You can buy pre-mad bi-wire cable that connect from your receiver in the standard fashion, but have 4 ends at the speaker side. Hook them up as idicated and you're ready to rock.
2. Use an additional pair of wires (same length), and hook both pair to your receiver as normal and one pair to each top and bottom pair of speaker terminals.
3. Connect one pair of wires from "speaker A" to the top or bottom, and the other pair from "speaker B" to the other terminal.
These are listed from 1-3 for ease of use, but 3-1 ( or #3,1,2 depending) for sound quality when "speaker B" is not being used.
__________________
Make it Funky!
gidrah is offline   Reply With Quote
Old 04-11-2003, 04:36 AM   #4
F1nut
Polk Guru
Default
Mark,
If he uses the "A" & "B" set up, his receiver isn't going to like it.
Old 04-11-2003, 04:58 AM   #5
gidrah
Polkologist
Default
Why not? It's to the same speaker. His impedence isn't going to change. The only issue would be if he had separate internal amps for A & B, which Denon receivers don't have.
Old 04-11-2003, 05:10 AM   #6
F1nut
Polk Guru
Default
I'm too tired to think about this anymore tonight. You might be right, I'll look into it tomorrow.
Old 04-11-2003, 05:28 AM   #7
gidrah
Polkologist
Default
Quote:
Sissy!:lol:
Old 04-11-2003, 02:25 PM   #8
eulogyt00l
Polkie
Default
Thanks for the warm welcome and the info guys, that makes it alot more clear for me. At least now I know I'm not losing my mind by only seeing 1 speaker jack on my receiver. I just wish I would have known about this before I bought my regular speaker wire a few weeks ago. I guess now I will have to get the bi-wire because it makes sense to me how it would improve the sound quality. By the way, which speakers are you normally supposed bi-wire? All of them, or just the front channels? Thanks again!
Old 04-11-2003, 02:42 PM   #9
RuSsMaN
Hardcore
Member Sales Rating: (27)
Send a message via AIM to RuSsMaN
Default
Don't do the A-B terminal crap, that's ghetto bi-amping.
__________________
If you're gonna be dumb, you gotta be tough - when you get knocked down, you gotta get back up - Roger Alan Wade
RuSsMaN is offline   Reply With Quote
Old 04-11-2003, 05:18 PM   #10
TonyPTX
Polkazoid
Send a message via ICQ to TonyPTX Send a message via AIM to TonyPTX Send a message via Yahoo to TonyPTX
Default
Quote:
You don't HAVE to buy bi-wire speaker wire. You can do what gidrah suggested and just double up two runs of regular speaker wire, lamp cord, whatever you're using, to each speaker. At one end you twist the two positives together and the two negatives together then put the positive on the positive terminal of the receiver and the negative to the negative terminal on the receiver. Then remove the jumpers on the back of the speaker as mentioned, and put each of the positive ends to the two seperate postive terminals and likewise for the negatives. Repeat for the other speakers.
As a word of caution, triple check to make sure you don't have the positives and negatives mixed up on each run or your receiver may go up in smoke like a Cheech and Chong movie.
This is a simple one, bi-wire any of them that have two sets of terminals in the back
Tony
__________________
Damn....8 lines...I've gotta put my sig on a diet now....
TonyPTX is offline   Reply With Quote
Old 04-11-2003, 05:51 PM   #11
STUFFMD
Polkateer
Default
Yea I second that Eulogyt...I started out with the same kind of wire in bi-wire situation on my 800's...and upgraded about a year or so later....that's the fun part of audio and tweeking you can always upgrade 1 piece at a time later. I have 2 different kinds of wire currently in my situation after playing around...still want to upgrade to the smoother Monster Z2 for my HF.....
It only costs money...but the beauty is you don't always have to fork it out all at once with this "Hobby".
Good luck, look forward to hearing your tweek results on the posts.
Stuff
__________________
Your system is only as good as your weakest component...!
OnkyoTX-DS 797
NAD C270/ Mains
Mains: LSI9's
Center: Cs400i /Biwired
Rear: Fx300i
Rear Center:CS 245i
Dvd: Onkyo DVS 555
Vision RCA 36" Premiere Series
Bang & Olfsen RX Turntable
Psw 350 Front/Psw 202 rear
Kimber Cable 4TC Mains HF
Monster Originals/Center
Kimber Interconnects
Monster XP Everywhere else
PS2/Gamecube
STUFFMD is offline   Reply With Quote
Old 04-11-2003, 08:20 PM   #12
mantis
Polk Guru
Send a message via AIM to mantis
Default
Anyone catch what Denon receiver he has?????
eulogyt00l,
What Denon receiver do you have?If you have a model under the avr4802,then I would suggest upgrading the receivers before you spend money on bi wiring.Get your read on.Bi wiring has been gone over many times in here.Do a search,get a cold drink and get your read on.........after you get a basic understanding,feel free to ask away.........Lets talk about that receiver first............
__________________
Dan
mantis is offline   Reply With Quote
Old 04-11-2003, 09:45 PM   #13
F1nut
Polk Guru
Default
Alright Mark, call me a sissy will ya. Ha, take that.........lol.
Now, back to the topic. Running A/B together, it seems to me that the impedance of the high pass and the low pass would act the same as if you were driving two sets of speakers. Something that receiver isn't going to like. Any EE out there want to chime in?
I still say to do it right, use pre-made bi-wire cable. The rest of it is just, well....ghetto (thanks Russ) bi-wiring.
Old 04-11-2003, 09:45 PM   #14
Frank Z
Polk-a-dweeb
Default
Here's a good read for anyone that may be interested.
http://www.sonicdesign.se/biwire.html
__________________
2005-06 Club Polk Football Pool Champion!!
Frank Z is offline   Reply With Quote
Old 04-12-2003, 03:26 AM   #15
eulogyt00l
Polkie
Default
Great info guys, you have all truely been a big help with my wiring illeteracy. TonyPTX I am using the Monster THX1000 so doubling it up on the receiver end would be kinda unpractical (because they are huge and floppy at the ends) but thanks for answering my question and being very clear cut I didn't get all the A+B stuff at first. So I guess I will just bite the bullet and get some bi-wire but I don't think I will go with Monster this time because their bi-wire is at least $150-$700 A PAIR!! So if you guys have any suggestions on good quality speaker wire I would appreciate it. My amp is the Denon 5803.
Old 04-12-2003, 05:35 AM   #16
danger boy
Polk Guru
Default
i suggest you shop on ebay for wires/cables. I bought a 15' pair of Monster Z2 biwires for $106 and they are new too. they usually run between $199 to $275. not to shabby huh?
There are great deals to be had on those online auctions.. you just have to be patient and then snipe someone to get the best deals.
__________________
I need a new sig...
"Ask not what can your stereo system can do for you, ask what you can do for your stereo"
- little ol me
danger boy is offline   Reply With Quote
Old 04-12-2003, 07:40 AM   #17
mantis
Polk Guru
Default
What do you mean when you said monster bi wires where 150 to 700 a pair????Is that 2 much for speaker wires????
So far I see a 4300.00 receiver,Lsi speakers.Matching higher end wire would be in order.Wire I would suggest would be the Monster M1.4s bi wires for Front 3.Rears for max performance you could buy M1.4s bulk.If all rears are going to be ran in small(which is what I'm thinking here with a 60hz crossover setting)You could get away with MCX bi wire bulk for the rears....but thats totally up to how you feel about quality wire........There are many many brands out there,they all sound different.Finding the cables that will benefit your system is the hard part.
Old 04-12-2003, 02:57 PM   #18
eulogyt00l
Polkie
Default
Mantis I know its expensive gear but call me old fashioned when I think, that much money is ridiculous for wire. I mean last time I upgraded my home theater back in like 1995 speaker wire was dirt cheap. But I guess things change. Anyway I am now considering the Monster z2 because I have been seeing some good deals on Ebay. But I am unsure weather to go with the z2 or make the jump to the M2.4 for the fronts. I noticed Danger Boy said is using the Z2 and Mantis recomended the Mseries. Do you guys think the Mseries would be better for my setup than the Z2's? And one more question. Is there bi-wire that is actually long enough for to reach the surrounds? Because in particular on Monster's site they only go 15' max. So would I have to buy multiple pairs, or what?
Old 04-12-2003, 03:04 PM   #19
F1nut
Polk Guru
Default
IMHO, bi-wire the fronts and single-wire the rears. I highly recommend MIT cables. Get the best you can afford.
Old 04-12-2003, 03:40 PM   #20
eulogyt00l
Polkie
Default
Thanks for the advice F1nut. I never even heard of MIT, but I did a google search and found their site and they look like they have some nice cables. I'll have to check them out, although I am kinda partial to monster since I've been dealing with them for awhile now. I still am undecided on the z2 or M2.4's and now MIT ad's another alternative.
Old 04-12-2003, 03:56 PM   #21
F1nut
Polk Guru
Default
I use to run Monster until I discovered MIT. Currently I am running MIT MH-750 Shotguns (bi-wire), but MIT has replaced that model with a updated verison. Look here, http://ecom3.aspre.net/cgi-bin/TheCa...ny.storefront/
and here, http://www.audiogon.com/ for good deals on used cable. Also, Transparent and Kimber make nice wires too.
Old 04-12-2003, 04:09 PM   #22
eulogyt00l
Polkie
Default
Awesome, and they have probably been burned in already. I will definetely keep checking those sites, I was looking for an alternative to Ebay.
Old 04-13-2003, 06:45 PM   #23
mantis
Polk Guru
Default
eulogyt00l
you can buy M1.4s in bulk.M2.4s you cannot buy in bulk as far as I know.
Bulk means a spool of it or the amount you would need.You can go down to Tweeter in your area and order a spool,or buy a spool and use what you need,and see if they will return the unused amount.They do it with all other bulk wire......
Old 04-13-2003, 07:21 PM   #24
RuSsMaN
Hardcore
Default
Thats cool, that they might let you return the unused portion.
Cheers,
Rooster
Old 04-13-2003, 07:24 PM   #25
mantis
Polk Guru
Default
I never saw anyone return M1.4s in bulk,but then again I don't work in the store.Most people(and very few)that wire there own houses,will buy a spool and we allow them to return the unused amount.I don't really see why M1.4s would be any different other then it's a order only Item.
Old 04-14-2003, 03:33 AM   #26
eulogyt00l
Polkie
Default
Thats cool. I might try and do that. But I found a very interesting website, you guys outta check out. These people claim their cables can outdo a $17,000 pair of MIT Oracles. I am very tempted to try them. They aren't that expensive at all either. Here's a link.
http://www.the-music-cable.com
Old 04-14-2003, 04:24 AM   #27
danger boy
Polk Guru
Default
wow.. yeah their prices aren't that high actually. Why would anyone spend $15,000+ on cables? Really, when you break it down and think about it all. cables are just wires.. yeah some claim to have a special mix of 99.9% silver.. but does that reallly cost $15,000?
I believe that good cables do improve your sound quality. but if you have a weak or so so source and a weak amp.. those expensive cables aren't going to do anything more than amplify the weaknesses in your system.
that's my take on the whole overpriced cables thing. I don't use entry level cables on my system... but i also don't see the benefits of cables that pricey.
Al
Old 04-14-2003, 05:32 AM   #28
F1nut
Polk Guru
Default
That's a mighty big claim, but who knows! I could see them besting some MIT Terminator 5's (entry level), but Oracles?!? Since they have been around awhile now, how come none of the A/V rags haven't reviewed them? Maybe you've found something, if you get them, please post a review.
DB,
Yeah, $15,000 is hard to take, but there is magic in those MIT boxes. I don't know about $15,000 worth, but magic none the less.
Old 04-14-2003, 03:53 PM   #29
Pablo
Polkazoid
Default
I'm also interested in how (and if) to bi-wire. But after reading this thread I am still confused. I'm fairly new to a nice system, and want to hook it up correctly, but don't nessecarily need to go out of control.
Somewhere in here it says to run 2 sets of wires from the output on the reciever to each of the inputs on the speakers. If run 2 sets of cable from the same outputs, isn't that the same as just jumping them at the speaker inputs anyway?
denon avr-3802
rti-70 fronts
fxi-30 surrounds
panasonic wfx95pt56 hdtv (also used for center)
(still on the list: another set fxi-30 -rears, psw404 sub)
P.S. $15,000 for cables?!?!? Unless you have money comming out the wazoo, and spend 10x that amount each component, your out of your mind. Either way, unless you have had dog's ears surgically implanted in your head, you're not going to hear much of a difference. Human hearing is one of the worst set of ears on the planet.
__________________
Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTV
Denon DVD-2910
Xbox, Gamecube, PS2
Pablo is offline   Reply With Quote
Old 04-14-2003, 06:15 PM   #30
F1nut
Polk Guru
Default
Quote:
No, because when you bi-wire, the high and low pass are seperate.
If you have the chance, go demo some high-end wires and then see if you still think the same.
True....
BTW, welcome to the forum.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
