| Register | System Showcase | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#1 |
Polkie
Member Sales Rating: (0)
the amp i want to buy has these specs...
75 watts RMS x 4 at 4 ohms 125 watts RMS x 4 at 2 ohms 255 watts RMS x 2 in bridged mode 4-ohm stable in bridged mode 2-, 3-, or 4-channel output Tri-Way capable variable 40-500 Hz low-pass and high-pass crossovers, 12 dB/octave variable bass boost (0-12 dB) at 45 Hz i was thinking about this being the first amp that I buy and running it tri way to the fronts and to the subs.. so does that mean.. that i can run the fronts @ 75 watts max & the sub @225 normally i would just buy a mono amp and just push my subs but i want something in the front until i get my other amp thanks Whiskey Moodz |
#2 |
Polkhead
Member Sales Rating: (1)
Tri-way output - when a special passive crossover is used with an automotive amplifier to safely power a subwoofer in bridged mono (low pass circuit) as well as a pair of stereo speakers (high pass circuit). Normal inductors and capacitors can be used for Tri-way output.
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
