Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 04-15-2003, 11:58 PM   #1
ezc
Polkateer
Member Sales Rating: (1)
Default Internal Speaker Wires
Has anyone replaced the speaker wire from the cross over to the speakers with better wire, or better termination to the speaker? I have a set of LSi speakers & my LSiC crossover wasnt working, Polk sent a replacement one that we installed. I figured the internal wires would be some exotic heavy gauge wire soldered to the speakers & crossover. The wires in my LSiC looks like standard monster cable speaker wire and are soldered to the crossover, the speaker end is crimped on & pushed on to the speaker ( male female type of connection, like a car speaker). With all the high priced speaker cable & all the hi tech ends for better connections, wouldnt it make sense to have a high preformance termination right at the speaker, or at least soldered directly to the speaker terminals? Im not sure if it would make a difference, has anyone tried replacing the wire or better terminations?
ezc is offline   Reply With Quote
Old 04-16-2003, 12:17 AM   #2
polkatese
Polk Master
Member Sales Rating: (10)
Send a message via Yahoo to polkatese
Default
ezc,
that is a very good point! but I think the rationale would be the short length of the cable to make any noticable difference....I think
__________________
Connoisseur of obsolete audio: Laser-Disc, DVD-Audio, HD-DVD, Dual-Disc
polkatese is online now   Reply With Quote
Old 04-16-2003, 12:54 AM   #3
F1nut
Polk Guru
Default
I know of one person here who upgraded the wires inside his SDA's and reported no change. It is a very short run, but if you do upgrade your wires, please give us a review.
__________________
'Political Correctness'.........defined
"A doctrine fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
F1nut is offline   Reply With Quote
Old 04-16-2003, 04:36 AM   #4
Tour2ma
Old School
Default
Ditto F1, but sounds like upgrading the termination could yield more than a wire change.
Any warranty voiding issues to consider?
__________________
More later,
Tour...
SOPA-PIAS Taste Good
"Death doesn't come with a Uhaul" - Dennis Gardner
"Life's been good to me so far" - J. Walsh
Stripped down system flooded by Ike (thanks alot motherf----r) ...
SDA CRS+ (floaters) - Carver C4 Pre (anchor) - Carver M4.0 (survivor by ~1")
Tour2ma is offline   Reply With Quote
Old 04-16-2003, 04:47 AM   #5
F1nut
Polk Guru
Default
Yeah, it seems that upgrading everything up to and including the crossover yields benefit. I haven't a clue about warranty issues, but that's a good point and you're right, it should be checked first.
BTW, looks like you got the bugs out, good to see ya back.
Old 04-17-2003, 08:17 AM   #6
mantis
Polk Guru
Send a message via AIM to mantis
Default
I don't see the need here.It's internal and short.Emi and RF is 2 reasons you buy better wire from the amp to the speaker.I'm sure polk used what they felt is the right internal wire for MAX performance and value.The crossover is designed to work with the drivers,tweeter and the design of the cabnet.....You feel you can do better then polk????Go right ahead.
__________________
Dan
mantis is offline   Reply With Quote
Old 04-17-2003, 08:46 AM   #7
RuSsMaN
Hardcore
Member Sales Rating: (27)
Send a message via AIM to RuSsMaN
Default
Steve gave me a peek of his LSiC network and cable. It actually appeared to be some of the BETTER internal wiring that I've seen.
I was impressed, to say the least. The wire did have a name on it, I can't remember what it was though. Anyone?
Cheers,
Russ
__________________
If you're gonna be dumb, you gotta be tough - when you get knocked down, you gotta get back up - Roger Alan Wade
RuSsMaN is online now   Reply With Quote
Old 04-17-2003, 12:56 PM   #8
mantis
Polk Guru
Default
Speakerking???I forget as well.I looked inside when I bought them.........
Old 04-17-2003, 12:59 PM   #9
RuSsMaN
Hardcore
Default
That doesn't ring a bell, could be though. It was a nice guage though, much thicker than you usually see.
Cheers,
Russ
Old 04-17-2003, 01:02 PM   #10
mantis
Polk Guru
Default
It was something King from what I remember.Yes it looks like older 12 gauge Monster wire.Clear jacket.....Hell I'll crack it open tonight when I get home.........
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
