Go Back   Club Polk > Getting Started > Basic Hookup/Wiring Questions
Reply
Thread Tools
Old 04-25-2003, 07:05 PM   #1
gacole2000
Polkster
Member Sales Rating: (1)
Default Yet again...a bi-wire question.
I used IXOS Gamma 13 to bi-wire my CS400. However, most info I have seen uses a 13/15 set up. My question is: is it imperative to have different gages of wire for HF & LF in a bi-wire set up? Any input is appreciated.
Thanks- Greg
gacole2000 is offline   Reply With Quote
Old 04-25-2003, 07:25 PM   #2
Zero
Stronzo
Member Sales Rating: (4)
Send a message via AIM to Zero
Default
Gacole,
Let me begin by congradulating you on making the decision to use Ixos. I have yet to find any cable/wire to exhibit a better value.
While owning and evaluating the performance of the Ixos super-gamma bi-wire on a pair of LSi-9's, I switched between the high-pass and low-pass band.
From the moment of that temporary experiment to my memory of it today, I have yet to conclude that a sonic difference indeed took place.
The conducted test was offset from the beginning. I already had the pre-concieved notion that there would be a difference between the 13 gauge, and the 15 gauge terminations. When I switched them I felt there was indeed a difference, a loss in clarity if you will. However, the differences were subtle enough to leave me without conclusion.
Going on my past experiences alone, I would not claim that it would be an imperative, giving the wire and the speaker we are dealing with. Since my test was inconclusive, perhaps you could conduct one yourself. The wire is cheap enough to take a little risk with....
Zero is offline   Reply With Quote
Old 04-25-2003, 07:32 PM   #3
gacole2000
Polkster
Default
I too am sold on IXOS. I use all their Gold interconects and I run 13 on front stage and 15 on 6.1 surrounds. Not to mention it is a GREAT value (it looks cool too)! I have the extra wire to experiment with, I was just wondering if the different gage effected which freq. went where, and by using the same gage on both????
thanks for the input- Greg
Old 04-25-2003, 07:51 PM   #4
Zero
Stronzo
Default
Gacole,
The idea behind the different gauges, if I remember correctly, is simply to provide the different bands with a certain amount of current. I have read that bass generally benefits from greater gauge wire, where as the high bands require less "heavy stuff".
Unless the amp caters specifically to bi-wire connections, I would not see how the frequencies could be specified simply through the wire.
Old 04-25-2003, 08:06 PM   #5
gacole2000
Polkster
Default
that's what I was thinking. Also, I seem to remeber a post here a while back asserting that in actuality, the HF should get the thicker wire. Did you see that?
Greg
Old 04-25-2003, 08:19 PM   #6
Zero
Stronzo
Default
Gacole,
I remember reading that here as well. Though due to a lack of knowledge and a short-term memory, I failed to remember the reasoning behind the idea. I am sure someone here will enlighten both of us once more.
Old 04-25-2003, 08:24 PM   #7
gacole2000
Polkster
Default
I as well, but I do remember it was a heated (as usual) debate and was supported with lots of technical mumbo jumbo-for what that's worth.
:-) Greg
Old 04-25-2003, 09:16 PM   #8
HBombToo
Polk Master
Send a message via AIM to HBombToo
Default
Its all about skin effect or the way the signal penetrates into the cable. Electron mobility resides on the surface of the material and I think its a bunch of bunk for audio or frequencies in the audio band but micro-wave is a different story. This is my engineering judgement and I'm sure there is an engineer out there that would disagree but I really don't give a shiite... minimize lossed and ensure good electrical connections and you'll be a happy camper.
HBomb
__________________
***WAREMTAE***
HBombToo is offline   Reply With Quote
Old 04-26-2003, 08:24 AM   #9
mantis
Polk Guru
Member Sales Rating: (10)
Send a message via AIM to mantis
Default
HBombToo,
why are the gloves out?relax man.Your opnion is as much value as the next guys.....
gacole2000,
Ixos has reasons for constructing there bi wire cables the way they do.Like KimberKable,they feel using different guages yield best performance for the job intended.
If you really want to know why,call Ixos and ask.I'm sure they will be happy to explain there wire theory with you.
Here's what I do.I don't judge a wire on how it's built untill it sounds good to me.Built quality goes along way with me after the fact.If the cable sounds like crap,it can be built as good as the best in the world,it doesn't matter at this point.Different guages,pretty colors,it doesn't matter unitl the wire can perform.Then built quality comes into play for me.
I say get your research on and learn why alot of companies use different guages to do different jobs.Some companies like Monstercable uses the same exact guage for all 4 conductors in there bi wire cables.
I'm not sure what or why which technic would be better.I'm no electrical engineer.But I do know what sounds good and what doesn't.
Wire is the finishing touch on a given system.Using the proper level of wire is what the goal is.Matching the correct sound with the correct sound(this is determined by the person building the system).Tweaking if you will.
Ixos is a really good wire company.I believe they have good reasons for what they do.Call em and find out first hand instead of getting opnions.
Thats what I do.
__________________
Dan
mantis is offline   Reply With Quote
Old 04-26-2003, 09:33 AM   #10
TroyD
Polk Guru
Member Sales Rating: (3)
Default
There's always a reason....most of them are marketing driven.
BDT
__________________
That statement will probably offend someone. They need to know ahead of time that I don't give a sh*t. -G.B. Grand
TroyD is offline   Reply With Quote
Old 04-26-2003, 03:20 PM   #11
mantis
Polk Guru
Default
everythings marketing driven huh Troy
Old 04-26-2003, 04:51 PM   #12
TroyD
Polk Guru
Default
Not everything, but a lot of it, yes. To think otherwise is niave.
BDT
Old 04-26-2003, 05:07 PM   #13
mantis
Polk Guru
Default
SO my question is how do you know what is and whats not?How my man how?
Old 04-26-2003, 05:26 PM   #14
TroyD
Polk Guru
Default
Ok, Dan, I'm going to give a VERY short lecture on marketing (I spent a few years studying it so pay attention) , the whole premise of marketing is to position your product in such a way that people will buy it. It's a pretty complex issue. Nor am I suggesting that it's all smoke and mirrors or fundamentally dishonest. You can have the greatest product in the world but if you can't get anyone to buy it, you are still screwed. This is the fundamental premise, you have to convince people that your product is unique in such a way that they will want to buy it.
How do you decide if something is for you? It's like toilet paper, I try it, if I like it, I stick with it.
Don't kid yourself, marketing is a HUGE industry and the audio world is not immune from it.
BDT
Old 04-26-2003, 06:00 PM   #15
mantis
Polk Guru
Default
Gotcha Troy,
I agree with that totally.Everything needs to be marketed somehow.It just seems you think things are marketing hype and not good products.I beg to differ on alot.
Old 04-29-2003, 06:42 PM   #16
PETERNG
Polkazoid
Member Sales Rating: (0)
Default
I think you're in a better shape if you use the same grade of speaker cable for the purpose of bi wiring, why go through the extra exercise to introduce trouble any way? Why using different kind of spark lugs to tune up your car? Why mixing tow different kind of anit-freeze for your cooling system? Why do you want the signal travel on two different road conditions to get to your speakers? I think you know the answer.
I stay out of the marketing issues, I do what make sense to me.
PETERNG is offline   Reply With Quote
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
