Upgrade to Latest Version
70-RT
70-RT, White
  • 7" Dynamic Balance® woofer
  • 2.5" midrange driver
  • .75" silk & polymer dome tweeter
  • Paintable Wafer-thin Sheer Grille™
  • Perfect for Dolby Atmos, DTS:X, Auro 3D, and IMAX Enhanced
  • Timbre matched to Legend, Reserve & RTi Series
700-LS
High-Quality Three-Way In-Ceiling Speaker with 5" x 6.5" Woofer
Stacking the woofer behind the driver unit is an innovation so extreme you won't believe the performance that results! Full-size speaker dynamics and a small-diameter cut-out built-in that virtually disappears into your decor. The Vanishing Series puts high performance stealth audio at your fingertips.
  • 5" x 6.5" Dynamic Balance® woofer
  • .75" Ring Radiator tweeter
  • Timbre matched to Legend, Reserve & LSiM Series
White
White
700-LS
  • Total Pieces 1
  • Included Accessories • (1) Polk’s Wafer-thin Sheer Grille™ - White, Paintable
  • Optional Accessories • (1) PB 50 - Pre-Construction Bracket - Sold Separate
  • Carton 1 9.75" (24.77 cm) h x 11" (27.94 cm) w x 13" (33.02 cm) d - 9 lbs (4.08 kg)
  • Qty Included 1
  • Availability US
  • Depth 8.5" (21.59 cm)
  • Driver Complement • (1)  2.5" (6.35 cm) d (Round) Dynamic Balance driver with aerated polypropylene cone - Midrange
    • (1)  5" x 6.5" Dynamic Balance woofer with mineral-filled polypropylene cone - Subwoofer
    • (1)  0.75" (1.91 cm) d (Round) Ring radiator - Tweeter
  • Grille Dimensions 8.13" (20.65 cm) diameter
  • Shape Round
  • Dimensions 6.5" (16.51 cm) diameter
  • Total Frequency Response 32 Hz → 33,000 Hz
  • Nominal Impedance 8 ohms
  • Sensitivity (1 watt @ 1 meter) 90 dB
  • Lower and Upper -3dB Limits 45 Hz → 29,000 Hz
  • Audio Inputs -
  • Speaker Inputs (1) Pair of Push Connectors - Gold-Plated
  • Recommended Amplifier Power Per Channel 10 watts → 150 watts
  • Lifetime Warranty Yes
