CSW100
In-Floor or In-Ceiling 10" Subwoofer
The Polk CSW100 is the least visually intrusive built-in subwoofer on the market today. It's designed for in-floor, in-ceiling or in-furniture placement. It fits comfortably between standard joists and the narrower QuietFloor spacing. Once installed, all you see is a tiny 4 1/2x14-inch grille (supplied). Visitors to your home will think they're seeing an air vent and they'll wonder where all that awesome bass is coming from!
CSW100
  • Total Pieces 1
  • Included Accessories •(1) Grille
  • Required Accessories •(1) Polk SWA500 - Digital Amplifier - Sold Separate
  • Cabinet Warranty 5 years
  • Drivers Warranty 5 years
  • Original Purchaser Only Yes
  • Carton 1 12.25" (31.12 cm) h x 15.75" (40.01 cm) w x 30.25" (76.84 cm) d - 37 lbs (16.78 kg)
  • Qty Included 1
  • Subwoofer Array Driver Complement •(1)  10" (25.4 cm) d (Round) Long-throw Dynamic Balance woofer with polymer composite cone - Subwoofer
  • Height 26.25" (66.68 cm)
  • Width 13" (33.02 cm)
  • Depth 8" (20.32 cm)
  • Weight 33 lbs (14.97 kg)
  • Grille Dimensions 4.5" (11.43 cm) h x 14" (35.56 cm) w
  • Total Frequency Response 27 Hz → 140 Hz
  • Nominal Impedance 8 ohms
  • Lower and Upper -3dB Limits 120 Hz → 33 Hz
  • Shape Rectangle
  • Dimensions 3" (7.62 cm) h x 12" (30.48 cm) w
  • Flush Mounting Depth 8.5" (21.59 cm) -
  • Audio Inputs
  • Speaker Inputs (1) Pair of Binding Posts - Gold Plated
