Upgrade to Latest Version
DB1042 SVC
DB1042 SVC, Black
  • High Performance Subwoofer for Automobiles, Boats, and ATVs
  • Marine Certified (IP56 rated): Dirt / Water Resistant, Tested for Salt-Fog, UV, Humidity
  • Slim Form Factor
  • 1-Year Limited Warranty
DB1042 DVC
10" Dual Voice-Coil Subwoofer with Marine Certification
Take your car, boat, or ATV to new sonic depths with Polk DB+ Series Subwoofers. You’ll get Polk’s thunderous, crystal clear and effortless bass from a marine certified subwoofer with a space saving design that’s easy to install and built to last.
  • Marine certified (IP56 rated)
  • Dirt & water-resistant & tested for salt-fog, UV & humidity
  • Used in Automobile, Boats & ATVs
  • 10" Dynamic Balance® dual voice-coil polypropylene woofer
Black
Black
DB1042 DVC
  • Total Pieces 1
  • Included Accessories • (1) Stainless Steel Mounting Hardware
  • Drivers Warranty 1 years
  • Original Purchaser Only Yes
  • Carton 1
  • Qty Included 1
  • Front Array Driver Enclosure Type Marine Certified
  • Front Array Driver Complement • (1)  10" (25.4 cm) d (Round) - Subwoofer
  • Shape Round
  • Diameter 9.05" (22.99 cm)
  • Full-Range Mounting Depth - Top Mount 4.33" (11 cm)
  • Full-Range Mounting Depth - Bottom Mount 4.57" (11.61 cm)
  • Total Frequency Response 28 Hz → 200 Hz
  • Sensitivity (1 watt @ 1 meter) 85 dB
  • Continuous Power Handling 350W
  • Peak Power Handling 1050W
