AVR-X2800H
7.2 Ch. 95W 8K AV Receiver Powered by HEOS™ with Dolby Atmos
$1,299.00
Enjoy incredible 8K video and immersive 3D audio from the AVR-X2800H. Fill medium-size rooms with more refined sound from a 7.2 or 5.2.2 set up with Dolby Atmos and DTS:X. And with HEOS® Built-in, wirelessly stream online music and share with HEOS-enabled speakers in other rooms.
  • 7.2 channels
  • 95 watts per channel
  • 8K Ultra HD
  • 3D Audio
  • Powered by HEOS™
  • 6 HDMI inputs
Black
Black
Availability:
  • Out of Stock
Out of Stock
AVR-X2800H
AVR-X2800H
$1,299.00
$1,299.00
Estimated to ship on {0}
AVR X2800H
Impactful audio for every moment
The ideal upgrade for new hi-fi enthusiasts, the 7.2-channel AVR-X2800H powers immersive home entertainment with support for Dolby Atmos, DTS:X, and 8K HDMI. Designed for medium to large home theaters, it drives speakers with a robust 95W per channel and supports HEOS® whole-home sound.
Upgrade your home theater
AVR-X2800H
Surround sound, simplified and supercharged
AVR-X2800H
With advanced 8K-ready HDMI inputs and outputs, the AVR-X2800H delivers seamless video compatibility and stunning picture quality with HLG, HDR, Dolby Vision, HDR10+, and Dynamic HDR pass-through. Effortlessly switch between sources with a one-stop entertainment hub for movies, shows, and gaming.
Stream music to HEOS® components in any room in your home. Play from Spotify, TIDAL, AirPlay 2, and more—all controlled through the HEOS app, streaming connect apps, or your smart assistant. Group HEOS-enabled devices for whole-home sound or curate vibes for every space.
Connect a 5.1.2 Dolby Atmos or DTS:X surround system for immersive 3D audio, build a 7.2 system with dual subs, or go with a small setup and use extra channels to power speakers in another room or outdoor space. The choice is yours.
Installation is effortless using Denon’s award-winning step-by-step video assistant and Audyssey room calibration. Whether you're a first-time user or an experienced enthusiast, you’ll get optimized sound that's perfectly tailored to your space.
Immerse yourself in rich, dynamic sound that keeps you in the action. AVR-X2800H enhances your gaming experience with ultra-low latency and lightning-fast response times—because every millisecond matters.
  • Amazon Alexa By simply speaking to an Alexa-enabled device, you can play music, adjust volume, switch inputs, and perform other functions without needing to use physical buttons or remotes.
AVR-X2800H
