Upgrade to Latest Version
Denon DRA-900H
DRA-900H, Black
  • High-performance two-channel amplifier
  • Expert sound engineering
  • Advanced 8K HDMI connection
  • Powered by HEOS™
  • Simple, intuitive setup
  • Built-in Wi-Fi and Bluetooth®
Denon DRA-800H
2.2 Ch. 100W 4K AV Receiver Powered by HEOS™
Denon stereo receiver built with Hi-Fi amplification seamlessly integrates with the latest Hi-Res audio, wireless, voice control and AV receiver technologies including five 4K Ultra HD HDMI inputs.
Black
Black
DRA-800H
  • DTS HD Master / DTS:X No / No
  • DTS Neo:X / DTS Neural:X No / No
  • DTS Virtual:X No
  • IMAX Enhanced No
  • Dolby TrueHD / Dolby Atmos/Dolby Atmos Height Virtualization No / No / No
  • Dolby ProLogic Ilz / Dolby Surround No / No
  • Auro 3D No
  • Audyssey DSX No
  • Multichannel Stereo No
  • Max Number of Processing (Preamp) Channels 2.1
  • Mono Block Power Amp Construction No
  • Discrete Power Amplifier Yes
  • D.D.S.C. HD Digital No
  • Pure Direct Yes
  • Gold Plated RCA Terminals Yes
  • Clock Jitter Reducer No
  • Alpha Processing No
  • Denon Link HD No
  • Audyssey No
  • Audyssey Dynamic EQ / Dynamic Volume No / No
  • Audyssey LFC No
  • Compressed Audio Restorer Yes
  • Media Server Yes
  • HEOS Wireless Multi-Room Technology Yes
  • Bluetooth Re-transmit for Bluetooth headphones Yes (update)
  • Alexa / Google Voice Assistant / Apple HomePod Yes / Yes / Yes
  • Lossy Formats: MP3 / WMA / AAC Yes / Yes / Yes
  • Lossless Formats: FLAC / ALAC / WAV Yes / Yes / Yes
  • DSD Audio Streaming Yes (2.8/5.6MHz)
  • FLAC HD 192/24 Yes
  • WAV 192/24 Yes
  • ALAC 192/24 Yes
  • Gapless playback Yes (FLAC, WAV ,ALAC ,DSD)
  • Photo Streaming (JPEG) No
  • Internet Radio Yes (TuneIn)
  • Spotify* Yes (connect)
  • Pandora Yes
  • SiriusXM* Yes
  • Other Streaming Services * Amazon Music / TIDAL / Deezer / iHeart Radio / Napster / Soundcloud / Mood Mix
  • HEOS App Control Yes
  • Compatible with Remote APP for Smart Phones Denon 2016 AVR Remote
  • Compatible with Remote APP for Tablets Android / iOS / Amazon Kindle
  • Ethernet Ports Yes
  • Wi-Fi Yes
  • Bluetooth Yes
  • HDMI Inputs: Back / Front 5 / No
  • HDCP 2.2 support Yes (HDCP 2.3)
  • HDMI Outputs: Main / Zone 1 / No
  • Video Conversion Analog -> HDMI No
  • Analog to HDMI Scaling No
  • HDMI to HDMI Scaling No
  • GUI Overlay on HDMI Yes
  • HDMI: 3D / 4K / CEC / ARC / InstaPrevue Yes / Yes / Yes / Yes / No
  • Enhanced ARC No
  • HDR / HLG / Dolby Vision Yes (HDR10) / Yes / No
  • ALLM (Auto Low Latency Mode) Pass-through for gaming Yes
  • 3D Signal Pass-through Yes
  • 4K Signal Pass-through / Scaling / GUI Overlay Yes / No / Yes
  • HDMI Pass-Through in Standby Mode Yes
  • Picture Adjust / Noise Reduction No / No
  • CEC Yes
  • DSD Audio Capability No
  • Audio Return Channel Yes
  • Auto LipSync Yes
  • Multi-Room Zones 2
  • Zone Audio Source: HDMI / Opt, Coax / Network, USB / Analog Yes (2ch) / Yes (2ch) / Yes / Yes
  • Zone Audio Output: Speaker / Preout No / Yes
  • Zone HDMI Output from HDMI Source No
  • IP Control / RS232 Control / Web Control / App Control Yes / No / Yes / Yes
  • Remote In / Out Yes / No
  • DC Trigger Output No
  • HDMI Diagnostics Yes
  • Auto Speaker Setup by Microphone No
  • FL Display 1 line
  • Graphic User Interface - GUI Hybrid GUI
  • ISF Certification No
  • GUI Languages 3
  • Setup Assistant Yes
  • Quick Select Plus / Quick Select Yes / No
  • Firmware Update by: Network / USB Yes / Yes
  • Variable Cross Over No
  • Optimized Bass Redirection No
  • Bass Sync No
  • ECO Mode Yes
  • Auto Power Off Yes
  • Sleep Timer Yes
  • Composite In / Out No / No
  • Component In / Out No / No
  • HDMI In / Out 5 / 1
  • Multi-room Video Out: Video / HDMI No / No
  • 2 / No
  • Phono (MM) In Yes
  • Digital In: Optical / Coaxial 2 / 1
  • Multi-room Out: Analog / Digital 1 / 0
  • Multichannel Preout Yes (0.2) / No
  • Subwoofer Out 2
  • 7.1 Multichannel Input No
  • Speaker Terminal: Gold Plated Screw / Regular Screw Yes / No
  • Number of Speaker Terminals 4
  • Speaker A / B Yes
  • Bi-amp Drive No
  • Multi-Room Speaker Terminal No
  • Front Inputs: Audio / Composite / Digital (Opt) / HDMI / USB No / No / No / No / Yes
  • USB Audio / Made for iPod / Made for iPhone Yes / No / No
  • AM/FM Tuner Yes
  • Number of Power Amps 2
  • Power Output (8 ohm, 20 Hz - 20 kHz, 0.08% 2ch Drive) 100 W
  • Power Output (8 ohm, 20 Hz - 20 kHz, 0.05% 2ch Drive) No
  • Power Output (6 ohm, 1 kHz, 0.7% 2ch Drive) 120 W
  • Power Output (6 ohm, 1 kHz, 10% 1ch Drive) 175 W
  • Metal Front Panel No
  • System Remote Control RC-1235
  • Pre-programmed / Learnable / LCD Display No / No / No
  • Power Consumption in W TBD
  • Power Consumption No-Sound (ECO On / Off) in W TBD
  • Standby Consumption in W 0.1
  • CEC Standby Consumption in W 0.5
  • Maximum Dimensions
    Antenna: Horizontal: (W x D x H) in Inches
    Antenna: Vertical: (W x D x H) in Inches
    W/O Antenna: (W x D x H) in Inches
    17.1× 13.3 × 6
    ( 17.1 x 13.3 x 8.5)
  • Weight in LBS 18.3
  • Power Supply AC 120 V, 60 Hz
  • Speaker impedance 4 - 16Ω/ohms
  • Input sensitivity 200 mV
  • Frequency response 10 Hz - 100 kHz — +1, –3 dB (Direct mode)
  • S/N Ratio 98 dB (IHF-A weighted, Direct mode)
  • FM section (Tuning frequency range) 87.5 - 107.9 MHz
  • AM section (Tuning frequency range) 520 kHz – 1710 kHz
