On-Wall Speaker Buying Guide
Article written by POLK STAFF
![](https://www.polkaudio.com/dw/image/v2/BGJH_PRD/on/demandware.static/-/Library-Sites-polk_northamerica_shared/default/dw0d31d1d3/CAT_Images/Built-In/Built-In_SubCat_On-Wall.jpg?sw=768)
ON-WALL SPEAKER BUYING GUIDE
Everything you need to know.
What are on-wall speakers?
On-wall speakers are multi-purpose speakers that mount directly onto your wall. They aren’t recessed inside the wall, so you won’t have to do any cutting or in-wall wiring as you would with in-wall speakers. On-wall speakers are very versatile: They can provide seamless sound in distributed home and commercial systems and act as surround speakers in a home theater system.
Are in-wall or on-wall speakers better?
This depends on your goals. If you are an aesthetically minded person, you might prefer flush, almost invisible in-wall speakers. Want low-profile models that give you the flexibility to move your speakers without cutting into drywall? On-wall speakers are for you.
How to choose on-wall speakers?
Choosing on-wall speakers starts with thinking about how you want to use them. Do you want a music listening room, a home theatre, or a multipurpose space? Will your on-wall speakers be left-right speakers, surround speakers, or speakers in a whole-home system? Size is important: The bigger the speaker, the louder the sound—and the bigger the visual impact.
Consider price in the context of your whole system. If you’re building a dedicated listening room or home theater, it makes sense to go with higher-quality on-wall speakers that deliver the clearest sound possible. If your speakers will be used for background music in a whole-home system, it might make sense to spend less on each speaker so you can use more speakers to cover a larger area.
What are the best on-wall speakers?
The best on-wall speakers are those that you can afford, provide great clarity and dynamic range, and work well in your space. It also helps if on-wall speakers come with multiple wall mounting options. (Our OWM3 on-wall speaker has seven, including corner and shelf mounts.)
Why buy a Polk on-wall speaker?
Buy a Polk on-wall speaker because we build ours with the same approach we take with all of our products—the best speakers at the best price. Our OWM3 on-wall speakers offer excellent dynamic range with impactful bass response, come with seven mounting options, and cost less than $200 for a pair.
