Denon DP-300F
Fully automatic analog Turntable
$399 MSRP: Price reduced from $499
The DP-300F has a sturdy base, adjustable balance, and anti-skating controls, meaning you’ll never miss your favorite part. It also features a switchable phono pre-amp for hookup flexibility. It’s a belt-driven, fully automatic Denon turntable that will help you descend into your cherished collection of vinyl.
  • Ultra-premium sound
  • Speed selector
  • Built-in phono pre-amp
  • Fully automatic operation
  • Belt-driven
  • MM cartridge
Black
Black
Availability:
  • In Stock
Denon DP-300F
Denon DP-300F
Estimated to ship on {0}
Special Holiday Bonus
DP-300F
A fully automatic turntable so you don't miss the details
Play records in one touch with a quality listening experience each and every time.
DP-300F
Rediscover your vinyl
DP-300F
  • Motor: AC / DC No / Yes
  • Drive System: Belt / Direct Yes / No
  • S-Type tonearm No
  • Operation: Automatic / Manual Yes / Yes
  • Auto tonearm lift at end Yes
  • Speed: 33-1/3 & 45 RPM Yes / Yes
  • Wow & flutter 0.10% (WRMS)
  • USB Direct Recording No
  • Phono EQ built in (switchable) Yes
  • Stylus (MM / MC) Yes / No
  • Stylus version CN-6518
  • Universal Headshell No
  • Dust Cover Yes
  • Rated Output 2.5 mV / 1 kHz
  • Frequency Range 20 Hz - 20 kHz
  • S/N ratio 60 dB
  • Rated Output Phono EQ 150 mV / 1 kHz
  • Frequency Range Phono EQ 20 Hz - 20 kHz
  • Available colors: Premium Silver / Black Yes / Yes
  • Maximum Dimensions
    Antenna: Horizontal: (W x D x H) in Inches
    Antenna: Vertical: (W x D x H) in Inches
    W/O Antenna: (W x D x H) in Inches
    17.1 x 4.7 x 13.8
  • Weight in LBS 12 lbs
  • Carton Maximum Dimensions (W x D x H) in Inches 19.5 x 17.9 x 7.68
  • Carton Weight (inc. product) in LBS 15 lbs
