Denon PMA-600NE
2 Ch. 45W Integrated Amplifier
Featuring Bluetooth streaming, digital inputs and a built-in phono equalizer, the Denon PMA-600NE integrated amplifier sets new heights in audio performance and connectivity for the aspiring music enthusiast.
  • Stereo amplifier
  • 45W per channel (8 ohms)
  • Advanced circuitry
  • Bluetooth
  • Digital inputs
  • MM phono
Black
Black
Availability:
  • In Stock
Denon PMA-600NE
Denon PMA-600NE
$599
$599
Estimated to ship on {0}
Special Holiday Bonus
PMA-600NE
Your introduction to what a premium amplifier can do
Listen to your favorite high-resolution audio content with the 192kHz/24bit D/A converter or connect and stream via Bluetooth.
PMA-600NE
Rethink what Hi-Fi can be
PMA-600NE
Add power to your Hi-Fi experience
PMA-600NE
Engineered with remarkable Denon amplifier technology, the PMA-600NE delivers 70 Watts of power-per-channel at 4 Ohm. This integrated amplifier offers compatibility with the widest range of speaker types and impedances for operational stability.
Experience high-resolution audio playback to enjoy the highest quality of your favorite songs
The PMA-600NE includes a phono equalizer that supports playing from sources with a MM cartridge. This phono equalizer has high gain, and unlike loops in other circuit board patterns which cause adverse effects on sound quality, the simple, straightforward design, significantly improves sound.
To eliminate interference and maintain exceptional sound quality, the transformer has separate coiled wires for audio and control circuits.
PMA-600NE
  • Channels 2
  • Digital in: USB-B / optical / coaxial / USB-A No / 2 / 1 / No
  • Sample Rate digital In 192 kHz / 24-bit
  • DAC chip PCM5141
  • Bluetooth / aptX / NFC Yes / No / No
  • Analogue Mode Yes
  • Advanced HC-TR single push pull circuit Yes
  • Wide range amplifier Yes
  • High current dynamic power supply Yes
  • Power amp discrete construction Yes
  • Micro processor auto off Yes
  • Balance / Bass / Treble / Loudness Yes / Yes / Yes / No
  • Shottky diodes Yes
  • Solid Heat Sinks Yes
  • Source Direct Yes
  • Audio Inputs 5
  • Phono Input: MM / MC Yes / No
  • Audio Outputs 1
  • Pre-out / Main-in subwoofer / No
  • Gold plated Cinch Yes
  • Number of terminals 2
  • Remote Control Bus in / out Yes
  • HEOS Link compatibility: IR / IP Yes / No
  • Headphone Out Yes
  • Output power 8 Ohm (20 Hz - 20 kHz, T.H.D. 0.07%) 45 W
  • Output power 4 Ohm (1 kHz, T.H.D. 0.7%) 70 W
  • Total Harmonic Distortion 0.02%
  • Input Sensitivity: MM 2.5 mV / 47 kohm
  • Signal to Noise Ratio: MM/MC 84 dB / No
  • Input Sensitivity: High level 110 mV / 30 kohms
  • Signal to Noise Ratio: High level 105dB
  • Treble Control ± 8 dB at 10 kHz
  • Bass Control ± 8 dB at 100 Hz
  • Available colors: Black / Premium Silver Yes / Yes
  • Metal Front Panel Yes
  • Power Consumption in W 185
  • Standby Consumption in W 0.3
  • Auto Power Off Yes
  • Remote Control RC-1234
  • System Remote Function Yes
  • Maximum Dimensions (W x D x H) in mm 434 x 308 x 121
  • Weight in kg 6.8
  • Carton Maximum Dimensions (W x D x H) in mm 520 x 370 x 207
  • Carton Weight (inc. product) in kg 8.1
